by sarahadjei238 Investigator
Retrieving a password
How can I retrieve my password to have access to the internet on my smartphone?
8 REPLIES 8
Re: Retrieving a password
Which pwd? Pwd to what? You don't need any pwd just to get on the Net itself. You would only need pwds to login to a/c's you may have on the Net & only you would know those.
Good Morning @sarahadjei238.
Welcome to the community.
Could you give us a little bit more information about this?
At what point are you asked for a password?
Hope to hear back from you soon 🙂
Jon
The password I am taling about is the password I want to retrieve; so that when I enter the password on my smartphone for WI-FI, I can have access to the internet on my phone.
Do you mean the WiFi pwd of the BB router you are wanting to connect your phone to? It should be written on a label on the router. What router do you have?
Hi @sarahadjei238.
Thanks for getting back to us 🙂
What WiFi are you trying to connect to?
Is it your own WiFi?
Jon
The WI-FI on my phone, on he net work, which is: EE-fkpxg6.
Hi @sarahadjei238.
Are you trying to connect to a router using the password?
As @XRaySpeX mentioned, there will be a label on the router with a password on.
If it's not a router, what is it that you're trying to connect your phone to?
Jon
EE-fkpxg6 is a typical Brightbox 2 WiFi network name (SSID). The pwd is to be found on the label on back of router under that SSID.
