by Billyt92
Registered btsport, upon validating number at btsport/ee it wont send the pin
I've sent text to 150 to - confirmed back that I've registered. Go to btsport/ee and enter number and postcode click send for that code and I recieve nothing
Any help would be great
Re: Registered btsport, upon validating number at btsport/ee it wont send the pi
Hi @Billyt92.
Welcome to the community.
I'd recommend contacting our Tech Care team about this.
They will be able to access your account and make sure BT Sport is set up correctly, and also help you to complete the setup process.
Jon​​​​​​​
