by garfieldthecat Established Contributor
Re: P20 pro dual SIM?
Has anyone double checked with EE? Or looked at an actual P20 Pro in a EE store?
I ask because other networks in the UK do sell the dual sim version. Three states on its website that it does; Vodafone doesn't, but I looked at one in a store and, much to the surprise of the shop manager who was sure they don't sell dual sim, it did have a slot for dual sim!
I understand most networks don't like the concept of dual sim as it's against their business model, but it's convenient to have personal + work sim on the same phone.
Solution
Hi @garfieldthecat,
Welcome back to the community.
The EE version is not dual SIM compatible.
Solution
Hi @garfieldthecat,
