by dansnell Investigator
RCS Not working
I'm trying to get RCS working on my S10e. I'm using the Google messages app and I've gone through all the steps and troubleshooting on EE's RCS page. Also gone through Google's RCS troubleshooting page.
Any suggestions?
Solution
Re: RCS Not working - my solution
I discovered in my About Phone my number was showing as the original number for Sim before the number port.
To fix this (since you can't edit your number on a Samsung). I put my sim into an iPhone (apparently blackberry works as well). In settings>phone>my number I can then edit the number.
Put it back into my Samsung clear the data in app settings for messages and carrier services.
Go back into messages and check chat settings. IT CONNECTS!!!
So ultimately the issue was a phone number misconfiguration.
7 REPLIES 7
by Brilliant Contributor
Re: RCS Not working
What is happening?
At what point us it failing?
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10 Beta)
Re: RCS Not working
It is constantly stuck on trying to verify
Re: RCS Not working
Try clearing data on google messages and starting again.
This happened to my wifes Huawei and I kept doing that until it started working.
Re: RCS Not working
I'll give this a try
Re: RCS Not working
Forgot to say also @dansnell
Download Carrier services from the play store as well.
Solution
Thanks for letting us know @dansnell
Glad this is now working for you and thanks for sharing your solution.
Leanne 🙂
Recent solutions
