by ChrisP4GEE Investigator
[QUES] Wifi Calling Limiting to Particular Wifi...
I have enabled just Wifi Calling on my Samsung Galaxy S7 (waiting for it to enable).
Is there a way to limit it to certain SSIDs? I have a WiFi hotspot in my car (EE 4GEE Wifi SIM), but I don't want it to use this for calls when in the car. I only want it to work at home.
Does the EE 4GEE Wifi SIM support WiFi Calling even?
by Profile closed
Not applicable
Solution
Re: [QUES] Wifi Calling Limiting to Particular Wifi...
You are not able to specify which WiFi SSIDs can work with WiFi calling sorry and yes EE data only dongles do allow WiFi calling to work when WiFi enabled handsets are connected to them.
by Profile closed
Not applicable
Solution
@Profile closed wrote:
You are not able to specify which WiFi SSIDs can work without WiFi calling sorry and yes EE data only dongles do allow WiFi calling to work when WiFi enabled handsets are connected to them.
Thanks, it's not a dongle though, it's just a 4GEE Wifi Pay as you go SIM car which is fitted to my car.
If I turn on the "Restict Networks" option under "Data usuage" for the Car's SSID would that stop it?
You mean "Restrict Background Processes"? No that's only for restricting data over the mobile network, not for restricting calls over WiFi. You just can't restrict WiFi Calling as you wish.
Ok, thanks. I'll just have to turn it off in the car and remember to turn it back on at home. 😞
by red_snow Established Contributor
You could consider using an Android app named Tasker. It takes a bit of getting used to  and seems daunting to start with.
However you could set-up "tasks", WiFi ON & WiFi OFF and then create a profile that will turn on or off depending on mobile towers located, geographical location or times etc.
