by Zxzach Investigator
Problems with p20 pro apps after recent update
Since Sunday evening my P20 pro has a major problem, it will not open lots of apps that worked fine before. Even worse is that as working apps get updated then they will not open either!
Any ideas?
Solution
Re: Problems with p20 pro apps after recent update
Hi @Zxzach
Thanks for coming back to me.
In this case I would give us a call on 150 and speak to our Tech Gurus they will be able to get this looked into for you.
Morning @Zxzach
What apps are not working now?
Do they have any comments within the app store advising this is not loading from other users?
Leanne 🙂
Lloyds Bank, Nationwide, Halifax, Gmail, BBC, One football, Meerkat, Absolute radio and plenty more. There are no comments on Google Play store 😞
Solution
Hi @Zxzach
Had to do a factory reset to resolve problem 😐
Glad it's working properly again, @Zxzach
Thanks for letting us know. 🙂
