Highlighted
Problems with charging
My charger that came with the phone is not giving me fast charge! What can I do?
Highlighted
Solution
Re: Problems with charging
@MPro87
  1. Open the Settings app.
  2. Tap on the Device Maintenance option.
  3. Look at the bottom left and tap on the Battery icon.
  4. Tap the 3-dot menu icon at the top right of the screen.
  5. Choose the Advanced Options option in the drop down menu.
  6. Touch the Fast Cable Charging option to flip the toggle off and on.
Highlighted
@MPro87   Is the charger able to do a fast charge?   And what device is it.
Highlighted
Fast charge plug that came with the phone. Have the S9
Highlighted
Solution
@MPro87
Highlighted
Good Morning @MPro87.
Welcome to the community 🙂
Let us know if you're now able to use fast charging following @Chris_B's advice.
Jon
