by milesfrankland Contributor
Problems with WIFI Calling and VOLTE
I have a Galaxy NOTE8 supplied on contract from you guys.  I was on the old android OS 7 and everything worked a treat.  Then an update appeared on my device - the new OS. Android 8.
Since updating to this my WIFI calling is now not usable, VOLTE is not usable.  I basically cant make or receive calls on my phone anymore.  EE seem to have disabled the menu option to turn off VOLTE?!
Problems:
On WIFI calling I seem to be able to make calls okay.  When I receive calls, they are just silent.  I have tried multiple WIFI networks in different locations.
On VOLTE making and receiving calls does not work at all.  I get a scratchy garbled noise both ways.
If I disable 4G all is okay.  I just dont get my 4G internet anymore!
I have tried resetting network settings on my phone with no luck.
Solution
Re: Problems with WIFI Calling and VOLTE
Finally got a call from EE support (I have been waiting 2 days for).  Got through to second line tech - they have confirmed an issue between iphones and samsung on WIFI / VOLTE calling.
Nothing I can do until they roll out an update.  They are currently waiting for Samsung at the moment.
I would have loved to have tried the factory reset...but I have been putting it off and putting it off as it will take up a lot of my time, which I dont have just now.
Thankfully I didnt try this for the reason above - it wouldnt have helped.
11 REPLIES 11
Hi @milesfrankland
Have you tried clearing the system cache via recovery? Or factory resetting?
Thanks,
Im just doing the cache partition wipe now.
I was trying to avoid doing a factory reset as last time I did this I lost loads of settings etc that the backup never restored and it took me ages to get everything back to normal!
EE Employee
Hi @milesfrankland and welcome to the community.
So I can try and assist, I don't suppose you know what the recipient device is that you get the garbled noise on.
Many thanks,
Lee
Thanks for the message.
I have had garbled calls with a iphone 8 and iphone x.
The silent calls have happened with iphone x.
EE Employee
Hi @milesfrankland, thank you for the information.
I have sent you a private message on here, so I can get some details from you.
Thanks,
Lee
Hi @Lee_H,
I have given you the requested contact details via PM.
Miles
Ive had no contact from EE as of yet!
Lee is offline so I cant ask him what is happening.
Is there anyone else from EE that can help me fix my phone that doesnt work like a phone?
VoLTE and Wifi Calling
Problems:
Re: VoLTE and Wifi Calling
Hello there @milesfrankland
Have you spoken to our technical support team?
Thanks, Leanne.
@milesfrankland
As I said in the second post, try factory resetting.
Thanks,
Solution
