by Barmy Established Contributor
Problems with MyEE app
I have been using the MyEE app for a couple of years and until last week it worked fine and provided the info I needed. I updated the app last week and then bought an extra 10GB of data after a mishap with Backup and Sync and Google Photos (my fault). The app worked fine for a day but then just started showing the following message whenever I try to log in
Sorry
Somethings gone wrong. Its our fault. We're trying to fix it.
I have a Samsung Galaxy S7 (not rooted, purchased from CPW)
Is anybody else having the same problem?
7 REPLIES 7
by Ace Contributor
Re: Problems with MyEE app
@Barmy
Try to reinstall and check if it work for you.
Many Thanks
Thanks for the reply.
I have already deleted the app and reinstalled it. It allowed me to enter my e-mail, password, PIN and it allowed me to use fingerprint recognition to open the app but then displayed exactly the same message.
by Ace Contributor
@Barmy
Go In your phone settings >APP >MY EE Click on that then storage and clear cache and try again.
Many Thanks
Tried that.
Cleared Cache - No good
Cleared Cache and Data - No good
Deleted, restarted, reinstalled - No good
The infuriating thing is that it used to work and also that when i re-install it tells me how much data I have and displays my number, it invites me to log in or register, as soon as I try to log in it displays the error message.
EE Employee
Hi @Barmy
Thanks for trying all the steps.
Are you a personal pay monthly customer?
If so I can send you a link to chat.
I think it might be worth logging this with our tech support teams.
Thanks - Karen. Smiley Happy
Karen,
Sorry for the delay in replying. I am a personal pay monthly customer.
I am still able to log in to My EE on the web, it's just the app.
EE Employee
No problem at all @Barmy
It definitely sounds like an issue with the app.
I'll send you a Private Message with a link to the tech chat team.
Pop back and let us know how you get on.
