by bcam--
Problem - outgoing phone calls
I have a Huaweii Y330 Ascend phone.   I can't make any outgoing calls.  Incoming calls are received ok.   I've never had this trouble before
Can anyone help/advise?
Re: Problem - outgoing phone calls
Hi @bcam--,
Thanks for joining the EE Community. Smiley Happy
Are you using a pay as you go or pay monthly plan?
Are you in the UK?
What happens when you try to make a call?
by bcam--
Re:%20Problem%20-%20outgoing%20phone%20calls
In reply - I have a monthly plan and I live in the UK.
This problem seems to be intermittent. Sometimes when I try to make a
call it is successful - but mostly I try to make a call, I get a screen
indicating the number is dialling, there is a long pause, then a short
bleep and disconnects.
This problem only revealed itself today - up to today my phone has
worked perfectly.
I had thought it might be an issue with the EE/TMobile transmitter or
network, rather than on my phone, as the problem seems to be
intermittent.
Thank you
Brenda
Re: Re:%20Problem%20-%20outgoing%20phone%20calls
Hi @bcam--,
Does the network status checker show any problems in your area?
