by cliffbradbrook Investigator
Poor network connection notification
Pixel 3 XL phone on latest Android update. Over the last few weeks I have been getting annoying sound notifications that there is poor network connection. Not the My EE app as turned off notifications. Has EE started doing this as I want to stop it? I know when I have poor network connection so don't need annoying sounds every few seconds.
Re: Poor network connection notification
Hi @cliffbradbrook
Try looking in settings - notifications. You might need to select all/system and then search for network notifications or something similar.
I cannot be more specific as I own a Samsung device, but I would suspect your option to disable this notification will be under notifications.
If you find the option, please let us know!
Hi @cliffbradbrook,
Do you get a text notification as well?
No text just a triangle in the notification area with EE in it and message below to state no network available
I have turned off notifications in the network area but doesn't stop it. I have just turned off Data Roaming to see if that helps.
Good Morning @cliffbradbrook.
Is there any options in your general notifications that could stop this?
Does the message look like it's a system message or actually from EE?
Jon
