by Philb84 Investigator
Pixel 2 won't charge
My phone has suddenly stopped letting me charge it. Coming up with a android message on my notifications bar saying something about not recognised. I've only had the phone 6 months
13 REPLIES 13
Re: Pixel 2 won't charge
Hi @Philb84
Have you tried a different cable/plug?
What is the message exactly and have you searched Google?
Ultimately if it needs repairing you can either contact EE about repairs or contact Google and claim under your warranty
The notification says analogue audio accessory detected. The attached device is not compatible with this phone.
The notification come up when I plugged charger in and noecant get rid of it
HI @Philb84
Is the port free form any dirt? Are you using a non standard cable?
Thanks,
Hi northerner
Yeah it's free from dirt. I'm using the cable and plug that came with the phone. It was this cable that caused the notification to come up.
Hi @Philb84,
Thanks for visiting the EE Community.
Do you have a different cable you can test with?
Hi James_B
I've just tried my wife's Samsung s9 charger and it worked but is charging really slowly
Hi @Philb84,
It looks like your charging cable has been damaged.
I would recommend purchasing a replacement.
I'll try. What about the notification I can't seem to get rid of now. Have you any ideas?
@Philb84. Have you tried restarting the device with out a cable plugged in to it ?
Hi Chris_B
Yeah I've tried that
Hi @Philb84,
Have you tried plugging in some USB-C headphones to see if that clears the notification?
Yeah I've tried that too. It just won't go.
Thanks for coming back to us @Philb84
In this case I would suggest giving our technical support team a call so we can run through some steps with you.
Let us know how you get on 🙂
Thanks, Leanne.
