by Gee47
Pixel 2 android 10 issues
  1. Anyone else getting probs with pixel 2after android upgrade ?
6 REPLIES 6
Re: Pixel 2 android 10 issues
Hi @Gee47
Have you tried factory resetting your device? A clean reset might help.
Hi @Gee47.
Welcome to the community.
What problems are you getting with your Pixel 2?
Jon
by Gee47
Hi
Since android 10 upgrade , my alarms or timers don't have sound . Some
calls are silent on both incoming and outgoing. Everyone I charge phone ,
it switches off the automatic battery's saver after running on battery
power. It's generally being a pain lol
by Gee47
Was thinking of a reset but as I've carried out a back up using android 10
, I'm not sure if the back up will work if using a lower android version (
according to Google warning notice )
Thanks for the information @Gee47 🙂
I'd recommend making a visit too an Android Forum to see if others are experiencing this.
These could be features that are adjustable or new.
Jon
by Expert Contributor
Expert Contributor
