by Andy3536
Phone number not recognised by website
Hello
Can anyone help.
I've topped my phone up using the T-mobile/EE website many times over years.
Always had the same number.
Now it tells me the number is not recognised?
Although my credit has run out, it's recieving texts and calls.
In the past i've used the payment method that didn't require loging in.
That doesn't work now (although it's only branded as EE, my sim was bought as T-mobile???)
I've created an account and logged on, and still it tells my it couldn't recognise my number.
Any ideas?
Kind regards
Andy
by Ace Contributor
Solution
Re: Phone number not recognised by website
HI @Andy3536
You need to call customer service on 150 from ee or any other provider to 07953 966 250 to escalate this issue.
by Ace Contributor
Solution
HI @Andy3536
by Andy3536
Thanks for the help.
Got it sorted calling them. 😉
EE Employee
Glad you are all sorted @ Andy3536
Many thanks,
Lee
