by TS24 Contributor
Phone not registered on network
Hi. I just purchased a new phone, and when I try to make calls it says not registered to network.
Please advise
17 REPLIES 17
Re: Phone not registered on network
@TS24   Is there a signal showing on the device?  Have you restarted the device?
by TS24 Contributor
Hi. Thanx for reply....yes has signal and have turned phone off and still nothing....
by Ace Contributor
@TS24 I would recommend contacting technical support on 0800 956 3146.
Afternoon @TS24
Where did you purchase the phone?
Did this come with a new EE SIM card?
Leanne 🙂
by TS24 Contributor
I brought it new and sealed on Ebay. I put my original ee sim in and when I try to make calls it says not registered on network.
by Ace Contributor
@TS24 has the sim got a use by date on it ?
@TS24   Does the sim work in your old device still.
by TS24 Contributor
No
by TS24 Contributor
Yes just tried it....works on old phone
@TS24  so it's not the SIM but the device.  It could possibly be network blocked. It might of been reported lost/stolen if it has that you have to take this up with the eBay seller.
by TS24 Contributor
The Ebay seller got it as an upgrade. Is it something that can be sorted?
by Ace Contributor
@TS24 If theres no service and the sim works in another phone it could possibly be blacklisted.
by TS24 Contributor
If the Ebay seller got it as an upgrade why would that be the case, and is there anything I can do?
by Ace Contributor
@TS24 you would be surprised by the amount of fraud committed around someone saying they have had the phone stolen to sell it on then claiming on their insurance.
by Ace Contributor
@TS24 you will need to speak with customer services to try and establish if that is the case ring freephone 0800 956 6000 opt 2 opt 4.
by TS24 Contributor
Thanx for your help. Is it free to call from ee landline?
Hi there @TS24
The number provided from @David is a free number to call from a UK landline.
Please keep us updated with your progress.
Katie 🙂
