by usc183
New Member
Pedometer on homescreen of Huawei p10 - change it be changed?
Is there any way of changing the pedometer shown on the homescreen of the Huawei p10?
I use a Polar a360 smartwatch and have it synced to both Polar Flow and Google flow but I would like the pedometer on the homescreen to show these steps and not those counted by the phone itself.
Is it possible to use Google fit as the pedometer on the homescreen instead?
Re: Pedometer on homescreen of Huawei p10 - change it be changed?
It depends on if your app you want to use has a widget. Check out the widgets. (long press on your home screen)
