by islandman75 Investigator
P9 lite stock firmware
 Hi, I did mess up with the phone and I need stock EE firmware to restore. Where can I find it?
VNS-L31C440
Thank you
Re: P9 lite stock firmware
HI,
EE don't release it so you will need to get it from Huawei, or you will need to send the phone into EE for repair.
can't do it. Did unlock bootloader, root and messed up...
by Brilliant Contributor
Then you have bricked your phone.
Do you not have a firmware restore on your PC component.
Rooting is always risky and shouldn't be done unless you know what you are doing.
done! on XDA forum rollback, there's a post which lets you roll back and change firmware to 432
