by MrSkins Contributor
P20 pro dual SIM?
Yes I know they're rarerer than hen's teeth at the moment but checking the specs, the P20 pro is dual SIM, has anyone tried two different SIM cards yet?
I bought the P9 lite from EE after being told it was dual SIM only to find out the second tray was locked by carrier.
by Brilliant Contributor
Re: P20 pro dual SIM?
Unfortunately Ee will not sell the dual sim version of any handset if you buy the dual sim from elsewhere sim free it should work however. Not all the p20 pros are dual sim
Thanks, I was kind of hoping a firmware flash would change that, there was me hoping 🙂
by stevo125 Established Contributor
Look up Funky Huawei - You may find something interesting there..... 😉
Top man, thanks :))
