by Graciebabe39 Established Contributor
Over heating
This is my second Google pixel XL and this one is over heating just like the other one. Any suggestions?
If it coninues to over heat  am I able to change phones as this seems to be occurring a lot on the Google pixel XL?
6 REPLIES 6
Re: Over heating
What do you mean by overheating as all phones get hot after prolonged use/charging for hours,  especially if they have metal frames.
Your phone will likely still be under warranty with Google so if you think it's defective then you should contact them.
by Brilliant Contributor
Re: Over heating
Do you close down all apps fully? Not just press home button.
How long do you use it for in one go?
How long is it sat on charge for?
How hot does it get?
Do you have a cleaner app installed. Most of these have the ability to 'cool down the phone (basically it shuts down all background apps and processes which is not needed so stops using CPU power which is what gets hot.)
Re: Over heating
I am just typing to daughters and the whole phone is hot. I take off cover and do nothing for half an hour so it can cook down. The covers bit to touch when I take it off. I have never had a phone that has done this. Playing music. I may as well give up it gets to hot.
Re: Over heating
Yes I close everything down I'm very strict with that. I may be on phone for say half an hour at a time, I have tried the cooler app but it then riiddles my phone with ads.  I charge my phone and then unplug phone. If I listen to music I am honestly worried about how hot it gets. It's not nice worrying about how hot it gets.
Re: Over heating
This is the second one I have had. It's warming up just typing this to you!?
This has never ever happened with any other phone I have had.
Also thank  you for replying.
Re: Over heating
Hi @Graciebabe39
Thanks for coming to community for some help and support 🙂
I would advise to please get in touch with our technical team either on the phone or via a live online chat.
Please do let us know how you get on and what they advise.
Thank you
Richard
