by eddie775
Oreo 8.0 on Samsung S8+ not fit for purpose
This update including the latest patches is the worst update I have had on Android phones. It has crippled the experience on my S8+ . My phone is slow. The touch interface is patchy and unresponsive especially around the edges. Applications do not update and take ages to install or uninstall. To update apps I have to go into settings and clean memory.
This should never have been widely released in this state.
Will give it a bit longer before I formerly lodge complaints through EE.
Re: Oreo 8.0 on Samsung S8+ not fit for purpose
Hi @eddie775
Try factory resetting your device.
The update works just great in my S8+
EE Employee
Hi @eddie775 and welcome to the community.
Please do follow the wonderful advice given above.
Many thanks,
Lee
