by OddyPlus
OnePlus 7 Pro 5G system software
Is ee controlling the updates for the oneplus 7 Pro 5G?
by Brilliant Contributor
Re: OnePlus 7 Pro 5G system software
Simple answer no.
What version firmware are you on though.
You may be confusing the 4G phone firmware like people did last time.
They have different firmware.
by OddyPlus
OK great
I realise their is several variants out on the market.
I'm on 9.5.10
I had read on the oneplus forums that potentially ee was slowing down the updates. Obviously the android 10 is around the corner and wanted to check.
Thanks Brendon
