by angelrod
OK Google doesn't work pixel 3
I got a new pixel 3 which was working fine until I got a Google home hub and a Google mini for my home.
Now, if I use the hot word my hub devices will respond but not my phone.
If I am away from home, my pixel doesn't reply to the command. I already double checked that the assistant is activated, retrained the phone with my voice and went through the step by step guide on the pixel help guide.
Any ideas?
by angelrod
Solution
Re: OK Google doesn't work pixel 3
Thank you RKB
I chat with a CSA in Google and they told me that if you have the battery saver on, voice commands don't work because that's a background task.
Thank you for your response. 😊
by Profile closed
Not applicable
@angelrod have you given permissions to Assistant to access your web searches and voice on your mobile? OK Google won't work on Android 8 without those permissions being given. I refused giving those permissions so I can't use it. I could use it on Android 7 without giving those permissions.
by angelrod
Solution
Thank you RKB
