by Stevemon1 Contributor
Nougat received today on S7
Just tried a manual upgrade and got it. Took about 10 mins to upgrade.
10 REPLIES 10
by Brilliant Contributor
Re: Nougat received today on S7
Lets hope there are no issues 😛
I must add that not everyone will see it straight away. It will be sent out in batches.
Can you also either:
  • Clear your cache;
or
  • Factory reset
After you have updated. Factory reset is the best option as this update is more than just some security update its a new OS update. This will ensure you have no/reduce the risk of any issues.
Thanks,
by neils31 Established Contributor
not showing on mine yet 🙂
there use to be a way of getting it to update if memory serves me correctly, think it was delete a certain file and it would then update, cant remember the details now ...
by Profile closed
Not applicable
Is your phone from CPW (XEU) or EE (EVR) ? Just I'm seeing XEU got it yesterday but not EVR as yet...
Mine is XXU  from a 3rd party supplier although my wife's was from CFW and hers is also XXU. Build G930FXXU1DQB1
Still no update here .......
by Profile closed
Not applicable
I think, possibly, the updates mentioned were to non EE customised firmware (EVR) phones eg. CPW (XEU) & probably a fair few others. It gets confusing as eg. Someone might have a phone on an EE contract but the phone was purchased from CPW rather than EE. It's all down to which CSC you have.
Might have been the case and I think that was established.
by Profile closed
Not applicable
Ok, was just trying to clarify the situation.
