by Brilliant Contributor
Nougat for S6/Note 5
Sammobile just announced that The Nougat update will be released for the S6/Note 5 in the third week of Feb. This is for Germany and Turkey but they are always aroudn the same time as the UK. So expect to see the BTU versions maybe 4th week of feb or beginning of March.
Re: Nougat for S6/Note 5
Note 5 was never released on EE so I believe.
As for the firmware generally if you are correct this will not be when its released on EE unless they have checked in advance all the exclusive services work on the EE network.
Thanks,
@Northerner
I believe I did state the BTU version on my post 😛
@BrendonH
Smiley Wink
Thanks,
