by Ace Contributor
Note 9 dual sim
Hi would the Note 9 dual sim work with EE’s WiFi calling & 4G calling thanks.
by Ace Contributor
Solution
Re: Note 9 dual sim
I got the device and it works with EE's WIFi calling & 4G calling.
Re: Note 9 dual sim
@David. Unless someone else has this device to answer your question EE can not say if it will work as I’m sure yiu know EE doesn’t sell the that device.
by Ace Contributor
Re: Note 9 dual sim
Yeah I know mate Samsung sell it by default directly though
Re: Note 9 dual sim
Hi @David,
If you get in touch with Samsung they should be able to confirm if it supports EE WiFi Calling.
by Ace Contributor
Solution
Re: Note 9 dual sim
