by tudberry Contributor
Note 9 September update ?
 This was released over a week ago now, when will EE update to N960FXXU3CSI3 ?
6 REPLIES 6
Re: Note 9 September update ?
Good Evening @tudberry
Your device will show a notification when the update is available for you.
 3 weeks and still no update ?
Hi @tudberry
As @Leanne_T said, it'll pop up on your phone once an update is available.
I'm well aware of what happens when an update is released. The question I asked stated that an update has gone out to other carriers and 'When?' was EE releasing it. EE always seems to be weeks behind everyone else.
Hi @tudberry
Check out our How EE works to test smartphone software updates blog. It'll give you an insight into how software is tested before release, timescales and more.
I think i may opt for a sim only contract in future and get the updates on time from the manufacturer.
