by Baz427 Investigator
Note 8 pie update
I've contacted Samsung and the Note 8 should have had the pie update in March 2019, when will we release this update.
10 REPLIES 10
Re: Note 8 pie update
Hi there @Baz427
Welcome to the community
Did you purchase your phone direct with EE?
Speak soon,
Katie 🙂
by Brilliant Contributor
Where did you purchase?
EE has released Pie on the Note 8 already.
Please dial *#1234# and share all info on there
Hi, phone was purchased second hand.
AP : N950FXXS3CRD2
CP : N950FXXU3ARA1
CSC : N950FEVR3CRC1
Model :SM-N950F
You have the EE firmware.
Pie has been released on EE have you tried using Smart Switch on your computer?
If not then maybe a factory reset will jig it into finding the update.
You only have the firmware as of 23/04/18 & have missed many updates since.
Hi, still no luck. Reset phone to factory settings. Still no update to pie
There may be a fault in your phone.
How technically minded are you? you could flash th Pie update yourself using odin
Hi mate, I'm ok at most things. Could you send some details please.
Go to sammobile.com and download the firmware. You can search for it under the firmware section and just enter your phone model etc.
They also tell you how to do it, you can also google how.
Thank you mate. Have a good evening.
