by Gavalar
New Member
Note 8 Freezing Issues
Hi
I'm the proud owner a Note 8 and up until now has been working brilliantly but i have now noticed some freezing and unresponsiveness when you press the wake up button.
anyone esle having this or similar problems
Re: Note 8 Freezing Issues
Try searching google for " Note 8 Freezing Issues" and you will see many people have encountered this issue with their Note 8.
Not sure there is any fix at the moment but you could look at other posts on google.
Thanks,
