by Neilps75 Investigator
Not recieving my text delivery reports
Anyone know why I'm by recieving delivery reports to text messages I have sent
16 REPLIES 16
by Ace Contributor
Re: Not recieving my text delivery reports
@Neilps75
Can you please tell us what is make and model of your phone.
Many Thanks
Samsung galaxy s7 edge, and 5s
Both seem to experience same issue
by Ace Contributor
@Neilps75
Have you check your message settings and turn your delivery reports on?
If you it turn on when you send text can you see checkmark tick ✔.
Checkmark in there it's
mean your message is send.
Many Thanks
Morning @Neilps75
Thanks for posting.
Have you managed to get this working with the help @tahirmian provided?
Thanks 🙂
Yes they are both set up for that and still don't recieve the delivery reports
by Ace Contributor
@Neilps75
checkmark tick ✔. Under send message means your message is delivered and this is your delivery report ✔.
Are you able to see checkmark tick ✔?
What kind of delivery report you want?
Many Thanks
Thanks for trying @Neilps75
Are you with us on pay as you go or contract?
Thanks 🙂
Contract
Thanks @Neilps75
Do you have a delivered message underneath the text conversation?
Thanks 🙂
No I normally would get  a text notification that itis delivered
Hi @Neilps75,
You won't get a text notification when using an Android phone, it will just be marked as 'Delivered' under the message bubble.
by Ace Contributor
HI @Neilps75 You can only get checkmark tick ✔ under your messege like this Pic.
 _20170704_174725.JPGand this checkmark is your delivery report.
Many Thanks
Android doesn't do that
Hi @Neilps75,
It can vary between different versions of Android and SMS apps.
Stock Android shows 'Delivered' under the text bubble - Can you see that when you turn delivery reports on?
Any of my stock android phones have never had that under  text they have only ever had the switch on button in setting menu
It seems to of happened ever since their was n issue with we over a month ago and since then not working correctly since. I have been done several things ie new Sims in both phones and reset them and still no difference
This is to be network issue as if it was a phone one it wouldn't happen on both some is a samsung galaxy s5 and other is  Samsung galaxy s7 edge
Hi @Neilps75,
Please get in touch with customer services so our technical team can look into this in more detail.
