by Bobizod1
New Member
Nokia 3 failing to charge. Any tips?
Nokia 3 has failed to charge despite showing that it "thought" it was. Now fully discharges. Any tips to re-charge ?
by Skilled Contributor
Skilled Contributor
Re: Nokia 3 failing to charge. Any tips?
A few steps, ranging from easy to nuclear! Reboot the device first of all to make sure the obvious issue of the thing just mis-reporting charge state hasn't occured.
1: Try a different cable
2: Try a different charger adaptor
3: Try a full system reset (Factory reset).
Hi @Bobizod1,
Welcome to the EE Community.
Did you have any luck trying @StopIt's great tips?
