Highlighted
by Investigator
No network in Furteventure
 I been to Furteventure a number of times and always had coverage. I received the standard text when I arrived and I have had no network since. I have checked all the normal settings and can  find a problem
Highlighted
Re: No network in Furteventure
Hello there @Paul1965
Thanks for posting on the community.
Can you try and select a different network as below.
Do you get service on a different network?
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Thanks. Leanne.
Highlighted
by Investigator
Hi
No only emergency calls, currently using Wi-Fi to post this
Highlighted
Thanks @Paul1965
Do any networks show when you try a manual network search?
Speak soon, Leanne.
Highlighted
by Investigator
I have done what you suggested again and it worked it found Orange. Have the same problem with my wife's phone. So will keep trying thanks for your help
Highlighted
No problem at all @Paul1965
Have a great time 🙂
