by rayaraddi Contributor
No missed call notification after Nougat update - S7 edge
Hello,
   After updating my S7 edge with Nougat, I don't see any missed call notification either on notification bar or on the dialer icon. I've wiped cache partition. Any ideas?
I would rather refrain from performing a reset, but just want to know if this can be resolved with a reset.
Thanks in advance.
13 REPLIES 13
Re: No missed call notification after Nougat update - S7 edge
Good afternoon @rayaraddi.
Thanks for coming here for help.
Are you using a third party call app at all?
Also have you tried rebooting in recovery mode?
Thanks, Leanne 🙂
I've rebooted the phone in recovery mode, but still have issues. I'm using the default dialer.
EE Employee
Hi @rayaraddi
Thank you for popping back with your comments, it does sound like you will have to back up and restore your device.
Please do let me know how you get on.
Many thanks,
Lee
Any idea which is the best software for backup / restore? Or is there any easy option? Kies is not supported on S7.
EE Employee
Hi @rayaraddi
@Northerner or @BrendonH will be able to help with this query as there Samsung users.
Unfortunately, I use an iPhone.
Many thanks,
Lee
by Brilliant Contributor
Kies was stopped from the Samsung Galaxy S6.
You will now need to downlod Samsung Smart Switch HERE
EE Employee
Cheers @BrendonH I knew one of you would know.
Many thanks,
Lee
No problem @Lee_H
Will be using it myself next Thursday when I get my S8+ 🙂
Apologies for my ignorance, smart switch is only for transferring data from old samsung phone to new one. How about backing / restore data
Download Smart Switch onto your PC. It also does back up and restore.
If you go into settings - accounts - google you can back up using Google. You can also back up if you log into Samsung on your phone and whatapp via the whatsapp app if you use it.
I would add this is a reported issue on the Samsung forums with this update so a factory reset may not work however this would be a good idea after a firmware update.
Thanks,
The issue has been resolved after I performed a factory reset. Thanks for all the help...
EE Employee
No problem at all @rayaraddi
Thanks for popping back to let us know!
Thanks - Karen. Smiley Happy
