by Jasonch89 Contributor
No WiFi calling option
 Hi all, i have a Galaxy S8, it was originally locked to O2, I had it unlocked when I moved over to ee
I've been trying to find the WiFi calling option but I can't find it anywhere, looked in all the places suggested in other posts and have changed APN settings but still nothing
Does anyone know why it's not showing up and what I need to do? Been trying to get it for over a month now, it's driving me mad
Thanks in advance
Jay
Re: No WiFi calling option
Hi @Jasonch89
It won't have WiFi calling as it's likely running O2 firmware. You either need to install EE firmware or BTU, but this is at your own risk.
Thank you mate, how would I go about installing the EE firmware?
@Jasonch89
Go to samsmobile, download it and follow the instructions. As I said this is at your own risk.
Thank you, will take a look now
