by rbertnitro
Network unavailable
Hi i have a back-up phone EE Harrier 16gb that is still brand new.i used it once to check when i got it that everything works.
I now need to use this as a backup phone but it seems to not want to connect to EE all attempts to register to EE network give the message 'network EE currently unavailable' however when i use the same sim card in my samsung s5 which has some sound and screen problems it automaticaly gets on EE right away so i can rule the sim card out.
So far ive tried doing a factory reset on the harrier but no joy.
Any ideas
Thank you
EE Employee
Re: Network unavailable
Hi @rbertnitro and welcome to the community.
Is the device your own or second hand?
Many thanks,
Lee
by rbertnitro
hi my device is my own it is still brand new only just out box i purchased it off amazon 1year ago as a backup
@rbertnitro
In addition to @Lee_H comments try inserting the SIM and factory resetting your device. Then if it doesn't connect then go into settings - network and manually selecting EE.
by rbertnitro
thanks northener. already tried that tried full factory reset and both auto network and manualy selecting EE both say EE unavailable. but its ok on other phone
EE Employee
Hi @rbertnitro
It may be worth giving customer services a quick call to run a handset diagnostic to see if there is anything to fault.
Many thanks,
Lee
