by Schenker
New Member
Net work not working properly
Is any one having same problem with ee
by Ace Contributor
Re: Net work not working properly
Enter the postcode for the area you are seeing the problem, and see if it reports any problems/issue.
http://ee.co.uk/ee-and-me/network/4gee/network-status-checker
Hi @Schenker,
Did the Network Status Checker show any problems in your area?
