by Rashidl5
My voicemail pin number
I forgotten my voicemail pin number
I will therefore appreciate if you can text it to me now.
by Ace Contributor
Re: My voicemail pin number
Hello @Rashidl5 it is not possible to have your voicemail pin sent to you via text message. You may be able to change it by calling 222 from your EE phone options 3, 3 for voicemail pin if you have not chosen to secure your mailbox when calling directly.
If you are unable to do this then customer service or Live Chat online can reset your pin:
http://ee.co.uk/help/get-in-touch
Hi @Rashidl5,
Welcome to the EE Community.
That's great advice from @tm90, did you manage to get in touch with customer services?
