by Dazzler74
My voicemail isn't working
by Alimsab
Re: My voicemail isn't working
Same with me.
It tells me I need a pin to access it and need to be in the UK???
I AM in the UK and used it yesterday so not sure what's changed since then?
Hi @Dazzler74 and @Alimsab
Welcome to the community.
Could you both restart your phones and let us know if it's any better this morning?
by Dazzler74
Hi Chris
Instead of the message saying the number is barred it now says I haven't got voicemail active! Although I have a message that I need to listen too
Thanks @Dazzler74
Could you try texting VM ON to 150 please?
by Alimsab
Back on, thanks
