by Rwcrocket Investigator
My texts are being received twice
by Skilled Contributor
Skilled Contributor
Re: My texts are being received twice
My partners iPhone does this from time to time, but that's an O2 device.
What device is it? Is it consistently sending 2 texts or intermittant? Is it only in areas with marginal signal for instance?
How long has the issue persisted for? Have you tried rebooting the device?
If these are messages being recieved to your device twice, the reverse questions apply. Is it from all sources or one in particular?
by Ace Contributor
Seconded. It happens to me in places where signal is low or patchy. Happens on all devices I have had but Apple iPhones appear to be the worst culprit. This has been on: Orange, T-Mobile, EE, Three, giffgaff, o2, Lycamobile, Vodafone, Voxi.
Good Afternoon @Rwcrocket
Is this to one person?
What phone are you using?
Also, do you receive duplicate texts?
Speak soon, Leanne.
MinMin an Xperia. Apparently only one recipient has the problem, so probably his device at fault. Thanks.
Hi @Rwcrocket
Let us know if anyone else notices this as well when you text them.
