by Laaries Investigator
My sim card is not picking up in Europe, I can't make or receive calls
I cannot make or receive call in Europe motog6
9 REPLIES 9
by Ace Contributor
Re: My sim card is not picking up in Europe, I can't make or receive calls
 Hi @Laaries
Welcome to the Community,
Could you log into your My EE account online
Then go to Menu > Manage Device > Roaming and also Call Abroad and Premium Rate > They will need to show as ticked for you to use your phone abroad.
If you can activate both settings this will update within 24 hours.
 could you also try these steps
Try re-booting your device
Turn the device off and back on or turn airplane mode off then on.
Perform a manual network search:-
•    iPhone – Settings > Carrier > Toggle Automatic OFF
•    Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
•    Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
If that doesnt work call EE tech support on 00442073620200 from a landline.
Neither of them worked. I can use my data... Enhance I am writing.
by Ace Contributor
@Laaries it sounds like you got a international call bar on your account.
Good Morning @Larries.
Did you check all services are active within your My EE account?
Katie 🙂
Good Morning @David
Thanks for coming to the community and posting super helpful posts.
As a thank you we would like to send you a small gift.
I am about to send you a private message for some further information.
Katie 🙂
Ok I had to tick international calls. Thanks for your help.
by Ace Contributor
@Laaries your welcome 😊
Yep I barred it months ago. My phone sometimes would dial out. Thanks
