by Jimmyjim101
New Member
My signal keeps going
I keep losing my signal on my phone and when I'm on important calls my phone cuts out because of the signal
Re: My signal keeps going
Hi @Jimmyjim101
Are you using EE 4G network or WiFi calling?
Have you checked EE Network Status Checker?
Hi @Jimmyjim101.
I'd recommend checking your postcode in our Network Status Checker.
Does this happen in all locations or just certain postcodes?
Is it happening on all calls or just some?
Jon
