by Michelle76
New Member
My samsung edge is telling me there is no valid sim in it
My samsung edge is telling me there is no valid sim in it but there is. This has happened over night notjing has chaneged yo my account. I have tried switch on and off but still saying the same so can't make phone calls
by Brilliant Contributor
Re: My samsung edge is telling me there is no valid sim in it
Take the sim out and carefully rub the gold contact part to clean it. Don't use a cloth or water.
Then reinsert to see if this works.
If not ask EE for a sim replacement. It is most likely the sim at fault than the phone.
To add to @BrendonH
  • Can you try the sim in another phone?
  • Did you get the phone from EE?
EE Employee
Hi @Michelle76 and welcome to the coimmunity.
Have you been able to follow any of the suggestions given above?
Many thanks,
Lee
