by Malxx
My samsung S8 has stopped using WiFi direct since the recent upgrade
Since the recent software upgrade my phone says there is no coverage, wbich is true, but it has stopped using the wifi for calls or texts.  The wifi is working fine.
by Brilliant Contributor
Re: My samsung S8 has stopped using WiFi direct since the recent upgrade
Hi @Malxx Go into phone then settings three dots at the top right and make sure WiFi calling is switched on
Hi @Malxx,
Welcome to the EE Community.
Did you manage to get it working again following @Damienw1's great advice?
by Malxx
Been through all the standard phone solutions.  EE tech support say it is a Samsung software upgrade (a patch) is causing the problem.. EE tec to liaise withe Samsung.  Getting back to me in 2 days.  Hmmmmm we'll see.
Hello there @Malxx
Thanks for coming back and updating us.
Let us know how you get on, when our technical team contact you.
@Malxx are you using an EE device or was it sim free or from elsewhere?
