Highlighted
My samsung A20E doesn't answer incoming calls
When a incoming call rings my phone and the screen shows the green answer icon when pressed there is no response phone just keeps ringing I am new to android
Highlighted
Re: My samsung A20E doesn't answer incoming calls
Hi @Pheobe1,
To accept a call, you need to touch the icon and drag it to the right of the screen.
Hope this helps.
Highlighted
Thank you I worked it out just after I posted   Thank you for advice
Just feel like a muppet now.
Pheobe
Highlighted
No problem @Pheobe1 🙂
Don't hesitate to let us know if you need help with anything else.
