by Yozza35 Investigator
My s7 edge will only charge when it's turned off!! Help!!
Hi all,
My s7 edge has suddenly lost the ability to charge as normal, deciding it will only charge when turned off! And only after a few attempts at it too.....
Has anyone had similar issues?
10 REPLIES 10
by Brilliant Contributor
Re: My s7 edge will only charge when it's turned off!! Help!!
Have You tried clearing cache or a factory Restore
Failing that try buying a new samsung official charging wire. As it may be your wire.
If none these work send it off for repair under it's 2 year warranty.
EE Employee
Great advice @BrendonH
Hi @Yozza35
Let us know how it goes after following the above steps.
Thanks - Karen. Smiley Happy
Wireless or wired charge?
I will be try these steps, thank you
Get Outlook for Android
Wired charger. It works if I turn it off
EE Employee
Morning @Yozza35
Did you manage to follow the steps given by @BrendonH?
Hi @Karen_C
I'm not sure what I've actually done but it seems to be working now.
I cleared the cache, put it in safe mode (checked a few things), was gonna reset it 2nite but I needed to charge it at work, tried it and Hey presto!!!
Thank you one the and all for all your help
@BrendonH
EE Employee
Aww that's great news @Yozza35
Happy to hear it's all sorted!
You know where we are if you ever need anything else.
Have a lovely evening!
Will do... You too
Glad it's working again.
Clearing the cache probably helped.
Probably some corrupt file along the way somewhere causing the issue.
