Highlighted
My phone will not connect t when trying to dial from USA
Hello,
I upgraded a couple months ago and informed EE I'll be working in the U.S. so need a plan to fit that. I'm currently in the U. S. now but the phone will not connect with any number I try and dial?
Highlighted
Solution
Re: My phone will not connect t when trying to dial from USA
Quick update. My phone automatically connected to t-mobile when I got here so I've just connected to AT&T and it works! However, will that incur extra charges? Thanks in advance!
7 REPLIES 7
Highlighted
Hi @Parky276
What plan/tariff do you have?
Can you log into your online account and try activating roaming? Also can you try manually connecting to one of the US carriers.
EE plans are not designed to be used for prolonged periods abroad, how long are you intending to stay?
Highlighted
Hiya, I'm on a max plan with 20gb. I actually went into the local EE shop and explained I'm working in the U.S. for 4 weeks at a time and upgraded my phone at the same time. I was told that I could use it the same as in the UK? I'll look at what you suggested too, thanks for your reply!
Highlighted
Hello there @Parky276
Can you receive calls and texts?
See our EE Roaming - Using your allowance abroad post for full information on using your allowance within USA.
Thanks, Leanne.
Highlighted
Solution
Highlighted
Hi @Parky276
You can connect to any network to get service at no extra cost.
If you're on a Max plan you can use your allowance when in America 🙂
You can use minutes, texts and up to 15GB of data.
Have a great time even if you are working!
Highlighted
Thank you very much, panic over! 😂
Highlighted
No problem at all @Parky276
Come back to the community anytime 🙂
