by Emmaprance
New Member
My phone keeps telling me I cant listen to voicemail because I dont have a pin
I've received a voicemail but I cant listen to it. I keep getting a message saying I cant access as I dont have a pin set up. And to dial 1 from my phone when in the uk and select option 3. I've tried this but get the same message.
Re: My phone keeps telling me I cant listen to voicemail because I dont have a p
Hi @Emmaprance
Thanks for coming here.
Are you in the UK or are you roaming?
Can you try your voicemail again today, is this working for you?
Leanne 🙂
