by Chelsy Contributor
My phone keeps connecting then unconnecting to my ee booster box
My Samsung galaxy s8 keeps connecting then unconnecting to my ee booster box but my partners is fine.
Re: My phone keeps connecting then unconnecting to my ee booster box
And how do i do that??
Sent from my Samsung Galaxy smartphone.
Have you activated VOWIFI on the S8? If so try disabling it as it's not needed with a signal box and maybe causing a conflict.
Welli did as i had no choice as i need to make phone calls during the day but have since deactivated it but still got nothing the only way i can het a signal at the mo is to have my settings on 2g or 3g. If i connect it to 4g i loose all signal.
Yea i did as i had no choice but i have since deactivated it but still got nothing the only way to get a signal at the mo is to have my settings on 2g or 3g as soon as i connect 4g i loose all signal
Hello there @Chelsy
Does this happen in all areas?
Are you able to try your SIM card in another phone, to see if this happens?
Speak soon, Leanne.
