by Gailey
New Member
My phone isn't able to connect to phone anyone ....
by Ace Contributor
Re: My phone isn't able to connect to phone anyone ....
Hi @Gailey  Have you tried turning it off and on again?
What phone is it, are you pay monthly or payg? If you do a manual network search and select EE, what happens?
