by Angie57
My new Samsung A3 2017 goes straight to voicemail when someone rings. Can Isortt
How do I stop my mobile going straight to voicemail? Samsung A3 2017.
Solution
Re: My new Samsung A3 2017 goes straight to voicemail when someone rings. Can Is
@Angie57  Have you tried turning your voicemail off and back on again to see if it resets to how it should be ?  Text VM OFF to 150 to turn off and give it a few minutes to update your settings.  Then text VM ON to 150 to re-enabled the service.
Solution
by Angie57
Success! Thanks.
Get Outlook for Android
by OneLove Investigator
I have the same problem, can anyone help me? Smiley Frustrated
EE Employee
Morning @OneLove
Welcome to the Community! Smiley Happy
Did you try turning your voicemail off and on?
Also it might be worth checking the Network Status Checker to see if there are any issues in your area.
Thanks - Karen. Smiley Happy
