by RachelA
My headphone jack isn't working and I have emergency calls only?
Since I updated the software on my phone the headphone jack has stopped working and now it says I have emergency calls only! What should I Do?
Re: My headphone jack isn't working and I have emergency calls only?
  • What phone do you have and did you get it from EE?
  • Have you tried restarting your phone?
by RachelA
I have a Samsung galaxy S7 edge and yes I got it through EE. I have restarted it but it didn't help! I have tried my sim in another phone and it works.
Get Outlook for Android
Can you boot into recovery and factory reset your phone?
Hi @RachelA
Thanks for coming to community to see us 🙂
Have you followed the advice @Northerner has given you?
Have you tried the headphones you are trying to use in another phone?
Just to try and rule out that the headphones may potentialy be the problem.
Richard
